I am tuning a 2011 Chevrolet Camaro SS with the LS3. The engine has a custom camshaft, Procharger P1SC-1, ID850cc injectors and a ZL1 fuel pump module. I was wondering what the minimum pulsewidth is on these Injector Dynamics 850cc fuel injectors. I am around ~1 ms right now at idle and my fuel pressure is set to the OEM static 58.0 psi for all the different conditions. I see a factory CTS-V & ZL1 have their tunes set to adjust fuel pressure from 50.8 psi to 65.3 psi. Would I be better off doing this to bring the idle pulsewidths up a bit?? I assume low flow is idle conditions?
