Results 1 to 13 of 13
Thread: wot knock!?
    Tuner in Training slobalt342's Avatar
    May 2014
    34
    wot knock!?
    my pe table is set to 12.8, I did a few wot pulls last night and adjusting the maf to get to 12.8. first pull I was at 12.2 with no knock. second pull I was at 12.4 with no knock. third pull I hit 12.7 with a lot of knock. so I thought I would richen it up and bring the pe table down to 12.5. and put my old map on where is was running 12.4 at wot, did a couple pulls today at 12.2 I got knock.
    im not getting it, one minute getting 12.4 at wot and when I go richer then that I get knock. should I start to pull timing where I get knock.
    someone please help ...
    tune is with maf
    every pull is 3rd gear at 2500 rpm
    I use 93 shell every fill up
    live in florida so maybe the heat ??????
    thanks in advance
    May 2014
    34
    in a 05 gto m6 forgot to add that
    Nov 2009
    All Around
    3,149
    whats your timing, and its possible that your IAT table was actually pulling timing. whats your timing set at?
    May 2014
    34
    It will vary sometimes I hit 25 of timing with no knock
    23 with knock.
    I zeroed out my iat spark till 140
    My iat never get that high, they never see 120.
    Maybe the owner before me ran low octane gas all the time ?
    May 2014
    34
    here is the tune im running.
    May 2014
    34
    here is my first log I did last night
    log 2 is the second one from last night
    and the 1234 is the one from today
    May 2014
    34
    this is from today
    Tuner in Training hook's Avatar
    Aug 2014
    Austin, TX
    29
    what are your mods?
    May 2014
    34
    Vararam intake long tubes catless and exhaust
    Aug 2014
    Austin, TX
    29
    copy the results from your MAF AFR ERROR histogram, make sure its on "L" and paste special onto MAF CALIBRATION table HIGH. Under Fuel and PE set your ramp in to 1.3000 and 0 for delay. I would remove timing in those cells to be safe, especially at wot. Just copy the entire table and paste special subtract into Spark High Octane table. Make sure to smooth out any major swings in timing of say 5 degrees or more. run wot again and repeat step one until the error is +-5. post the results
    Mar 2011
    Idaho
    29
    try some tr6 plugs? i got all kinds of knock on my ls2 with the stock plugs. once i put the tr6 plugs in i was able to add a few more degrees of timing with no knock.
    May 2014
    34
    I have tr5s gapped to 55 im gonna set my pe table to 12.6 and if I get knock I will just pull timing
    May 2014
    34
    So I ended up turning burst knock off.
    Got my afr to 12.6 this morning with no knock at all.
    I.also I advanced my timing to 26 from 25 up top
    I will do some more tuning this weekend. Maybe try for 12.7 and/or one more degree up top if no knock is present
    Then hopefully get on a dyno to see the progress.
