I may have something to contribute to this thread. I found that the rich after flash issue I have been experiencing is coming from an anomaly with my fuel pressure & injector pulsewidth. I've finally got a log of this to show (see attached). My fuel pressure decides to add about 10 psi to its normal operating pressure after I flash. However, the injector pulsewidth doesn't compensate for it like it technically should. Its like the ECU is ignoring the fuel pressure increase and continues to use an injector pulsewidth as if the fuel pressure is normal. So same pulsewidth at higher pressure = rich afr after flash. I notice that if I flash the car cold, it doesn't do this. Only if I flash after its hot and at normal operating temps.
Has anyone else seen this happening?
See the attached log. My normal fuel pressure at idle is 50 psi. You can see it is at 60 psi and slowly drops back down to 50 psi over about 15 min. Yet the pulsewidth stays the same.
rich after hot flash - fuel pressure drift.hpl
One last note...this is happening with a speed density tune and MAF turned off. I haven't confirmed if this FP anomaly happens with MAF or Dynamic mode.
