Results 1 to 13 of 13
Thread: Trying to go 2 bar on my 2010?
    Jun 2010
    559
    Hi guys, I'm trying to go 2 bar map speed density on my 2010 turbo gmc.
    My friend just bought a 2011 cadillac escalade with a turbo. Went trough the file and i saw that the truck is on 2 bar map speed density and have different tables on the airflow>general table.
    Will the speed density tuning of this year (2010 pcm) truck would be the same as to tune a 0411 pcm in speed density? I have my VCM scanner set up already wideband on just need some input.
    Here's a pic can't upload the file it's giving me problems.
    Advanced Tuner CatnipG5Bandit's Avatar
    Apr 2013
    El Paso, TX
    297
    Not sure what you are asking? The pic of the tune you posted is running a custom OS from HP Tuners. You can do the same thing on yours. The speed density stuff on your current program should be the ridiculous virtual VE. Buying the custom OS simplifies it.
    Jun 2010
    559
    What I'm asking and want to know is if I can tune the VE with my VCM scanner and won't need another tool?
    Apr 2013
    El Paso, TX
    297
    You'll need the scanner with some good pids, a wideband, and the VCM Suite. Also patience. If you want to run the stock virtual VE you'll also need this tool that translates the virtual VE into a VE table: http://www.hptuners.com/forum/showth...t-VE-Version-4
    Jun 2010
    559
    That's the tool it read about never use it so I went Maf open loop.
    But will like to go speed density.
    So I f I get a custom operation system the 2 bar map can I just use my vcm scanner and start tuning the VE?
    Don't want to mess with the blucat tool.
    Apr 2013
    El Paso, TX
    297
    Scanner, no. VCM Suite yes.
    Jun 2010
    559
    Yes the VCM suite.
    I just don't want to deal with the blucat tool.
    Thanks I will get the map sensor and buy another credit.
    Whats so complicated with the bluecat tool?
    06 Grand Prix GXP, LS4-full bolt ons, Tuned by me
    Jun 2011
    Montreal, Canada
    758
    The upgraded OS is free with the latest HPT upgrade so you don't need to buy credits for it.
    Tuner tonyvette's Avatar
    Oct 2013
    Macon, GA
    52
    Quote Originally Posted by GXPLS4 View Post
    The bluecat tool really isn't very difficult to use. It was intimidating at first, but once you get the hang of it it's pretty straightforward. And it works really well!
    2012 Colorado 5.3
    Magnum 70mm turbo
    RevMax 2800 stall converter
    DevilsOwn meth
    Jun 2010
    559
    Ok my understanding on this is that I can use the blucat with out going or buying credits to go with a custom operation system. If I don't use it i can always go speed density with a custom operation system and start tuning it without the blucat too right?
    Jun 2011
    Montreal, Canada
    758
    Quote Originally Posted by 02Ls1 View Post
    It is now free to get the custom OS. With it you don't need to use the bluecat tool.
    2007 Corvette C6 Vert. A6
    LME LS402, Pat G custom cam, ATI 10% OD Damper
    Circle D triple disc 2600, 3.42 Diff
    YSI, 3.0 pulley, ID 1000's
    Alky Control Meth,
    ARH 1 7/8 headers,
    1009 RWHP @ 7000, 817 RWT @ 6000
    Jun 2010
    559
    It's there some steps so I can follow and start tuning in 2 bar speed density?
    I have tune the 0411 pcm on 2 bar but I think this one might be different.
