Results 1 to 13 of 13
Thread: 04 pcm flashed with 02 os for better ve table
    Feb 2014
    32
    I was wanting to know if it was possible to flash a 04 truck pcm with the os off my 02 to get better resolution on my ve table for 3 bar map.
    Feb 2009
    1,931
    No, different pcms, not compatible.
    Feb 2014
    32
    Will a 02 pcm plug into the 04 harness
    13,564
    Still wouldnt work.
    02 is a cable Throttle body, 04 is drive by wire.
    Way too much different.
    Feb 2014
    32
    My 02 2500 gmc 6.0 is drive by wire and none of the gauges have to work because the 04 stuff if trasfered to a 70 firebird
    Advanced Tuner CatnipG5Bandit's Avatar
    Apr 2013
    El Paso, TX
    297
    Are you not running the custom OS? It's better than trying to mickey mouse something together and hope it works. Or use an '02 harness and everything else.
    Feb 2014
    32
    I was going to use custom os but when I changed it and looked at the ve table stayed the same size I decided to go for the 411 for better resolution
    Feb 2014
    32
    If you guys thick it won't make a difference in tuning out I will give it a shot but the is 20 kpa gaps in the boosted region
    Apr 2013
    El Paso, TX
    297
    Can you post a tune? The tables in the repository for both years look pretty close to each other. It's hard to tell without looking at yours.
    Feb 2014
    32
    I don't know how to upload tune to form
    Apr 2013
    El Paso, TX
    297
    Feb 2009
    1,931
    You can repin the 04 harness to work with 0411 computer. You will have to replace plastic green colored covers or grind tabs off to get into PCM. It will double size of ve table going this route.
