Looking for options. 6.2 6l90e Swapped Camaro
Here is what is currently in the computer
The Car is having issues with not firing some of the injectors. Wiring seems to be in check and everything points to PCM issues.
This car came to me with a laundry list of problems a major one being a VVT cam was installed with NO Cam phaser and a ton of other things.
If i get a PCM for this i want to be able to make sure it can be set up correctly.
After running all the numbers it comes down to a 6l90e which came from a 2500 6.0 truck. Motor was a 6.2 VVT motor.
