I have a boosted 2010 Camaro with the red label MAP sensor. Now that I've been turning up the boost above 10 PSI, it often trips a P0106 (MAP/Baro Sensor Range/Performance) error on fast acceleration. I have the linear & offset at 312.50 & -11.25. And the MAP Delta pegged across the board at 255.99 ("256") under Engine Diag -> General -> P0068 -> MAP Delta
The red label ZR-1 MAP sensor is a 3-bar, right?
Any suggestions on what to change?
