Just got done installing super cobra jet mono blade. Copied all the electronic throttle settings over from a cobra jet tune I have. Driving is awesome. Touchy touchy throttle pedal and I love it. Only issue I'm having is a hanging idle. As I slow to a stop I typically shift to neutral, mt-82 car. As soon as I do that the idle hovers around 1400-1600 until I come to a complete stop, then settles back out to the commanded 1k I have it set to. I've tried using the cobra jet dashpot settings...yeah that didn't work. I've tried with torque based decel on and off, with it on it's even worse, 2500-3000. I've tried playing with the etc throttle angle and the underspeed setting. I can only make it worse not better. I've tried going in the opposite of when I get some sort of response and end up back at 1400-1600 regardless. What am I missing here? I'll post the tune that I had prior to the mono as well as the current one that has the issue. You'll see a majority of the changes are in the electronic throttle tab and in the maf table. Everything else has been working great. Just need help figuring out this issue. ni-12 is the last tune on the twin 60 that was working great. mb-9 is the current that has the hanging issue. Also the cobra jet tune that I've been referencing for settings. Thanks for any help on this matter.
ni - 12.hpt
mb-9.hpt
2013 Cobra Jet 82 degree tune.hpt
