Anyone out there tried to run hpt custom 2/3 bar o/s on 0411 pcm with lean cruise enabled tune(speaking to the aussies out there). I have one here that works fine until you go into boost. Then the AFR subtractor becomes an adder and makes it run rich. This fixes itself when you drop below the enable speed but happens again anytime you go into boost. Anyone seen this before? Is there a solution?
