Results 1 to 2 of 2
Thread: IAT timing
    IAT timing
    First of all, is there a parameter in the scanner that monitors how much timing is being pulled due to IATs? I only see IAT advance and not sure if that's the right one.
    Also, am I doing this right in terms of IAT pulling? I zeroed out the 2 multiplier tables and just use the base table to pull certain amount of timing.
    But the other day I went out and tested this theory and was at 113* (should be pulling timing by then) but saw full timing even at high load. Thankfully I didn't have any knock but also didn't see any timing pulled. I'm starting to think that 1 of the 2 multiplier tables actually multiplies the base table and since I zeroed it out it's all being multiplied by 0 and thus there's no timing pulled ever?
    Attached is the tune
    Senior Tuner mowton's Avatar
    Mar 2007
    Florida
    3,773
    Set them both to 1's. This says use the IAT table 100% as stated. Any number less than that is a proportionally use of the IAT advance values (i.e .5 would use half the value). Zero says don't use at all.
    Ed M
    [email protected]
