need littel help in idle
hi all ,
i have camaro zl1 2012
Camaro ZL1 378 CID Supercharged Engine Package - 700+ HP
the problem is knock in idle . every time in idle the knock sensor reading start 1 KR to 8 KR i dont know what problem also AFR = 14.8 in idle i used tr8 spark plug ( NGK R5724-8 ) the fuel is 98 octane
I want to know from where can i fix this problem ?
knock in idle.hpl
how noisy is the engine, there there any vibration?
also post file and this is wrong section should be in GEN 4
I will assume you tried reducing timing but no change. Perhaps something loose or an extra sensitive sensor.
