Sirs
I installed a modified saab intake manifold on my LE5 to use the LSJ 2.5 bar map sensor with IAT being used there instead of at MAF. The info I have found on the new settings between 2 bar and 2.5 bar map linear and offset have been made, ZZP tune being the 2 bar.
Problem I am having is at idle in park or neutral the timing swings from -1.5 up to 34 and afr 11.? to 19.? back and forth till it dies. If you pull it into gear when it starts to die, it will straighten out. You can see this at the end of the log attached.
Thanks for your time
07 G5 GT 2.4L turbo
2.5BAR..DD-1.hpt
ZZP Start-up Tune.hpt
2.5test.hpl
ihavecash
