Results 1 to 2 of 2
Thread: Install wideband
    Aug 2005
    4
    Install wideband
    Just looking for some ideas as to how to route the cable from the sensor up into the car.
    I will probably leave it in the car for awhile untill its tuned.
    Nov 2004
    228
    Re: Install wideband
    i have i 04 ss commodore. i installed my techedge wideband on the passanger side cat pipe (pipe from manifold to cat) and ran the cables up into the engine bay and through a hole in the firewall right next to the passanger quater pannel. The hole was capped with a rubber plug from the factory. The cable came in behind the glove box and i router the cables along the gap between the bottom of the windscreen and dash and i connected it to the wideband controller which i stuck on top of my speedo as it has a display biult into the controller
    hope this helps
    Ronny
    04 VY Commodore ute M6 ls1, 918 valve springs, TR6 plugs, genttrbb twin turbo kit, 60lb seimiens injectors, Bosh 044 fuel pump, SX fuel reg, PLX wideband,Full Castle Hill Exhaust with 2 1/2in dump pipes, 4in cats into twin 3in cat back (no merge), Ripshift, oz700 clutch and 3.73 diff gears
Similar Threads
  1. A Special tip for Wideband Users....
    By soundengineer in forum VCM Suite Enhanced IO
    Last Post: 08-23-2012, 07:25 PM
  2. Wideband install questions
    By mowton in forum VCM Suite Enhanced IO
    Last Post: 09-20-2007, 11:13 AM
  3. lc-1 wideband install ?
    By bmfcamaro in forum VCM Suite Enhanced IO
    Last Post: 05-13-2005, 12:00 AM
  4. Which Wideband for me?
    By matts_222 in forum VCM Suite Enhanced IO
    Last Post: 02-15-2005, 04:05 PM
  5. Wideband sensor install
    By Confused1 in forum VCM Suite Getting Started
    Last Post: 12-09-2004, 10:59 AM
