Results 1 to 9 of 9
Thread: high ve/ high cylinder mass
    Sep 2012
    8
    so my engine is 408, 13-1 compression, big cam, e85 bosch 1000cc inj. so im thinking my inj data wrong. my ve table is very high and the car is still a tad lean driving around. and my duty cycle is high also. so I need help lowering my ve table to dial this in or ill take it to shop to get finished.
    camaro rtt.hpt
    good drive.hpl
    Couple of things I see as an issue first off. Where you are commanding fuel, you have a value of 1.25 as your OLFA value, and a value of 1.80 as your PE. Those are both really high values. I am not sure if you did that because it was running lean, or because you are trying to scale for e85, but you have the AFR stoich ratio correctly changed to 9.77X:1, so you are good to go for e85. But yeah, your VE table is astronomically high. Your IFR table seems accurate though.
    yikes on that VE table!! a config would help, so we can accurately asses your datalog, appears there's not much data being logged. not sure it's the issue, but set maf codes (at least p0103) to fail first. you can uncheck the box so the light stays out if you want, but that's up to you. i'd guess it's not failing maf. your VE is the reason for the hi g/cyl, as for ifr tables-more info is needed. is the fuel system return/returnless, and what is base pressure? also note the items 93camaro pointed out, i'd suggest setting at least the warm driving part of OLFA to 1.00, and PE to something that gets you a bit closer to a realistic afr....
    Sep 2012
    8
    i have the OLFA up alittle bit to knock the VE table down but still didnt help. i have the pe high cause of how high every other table is.
    more info, car is has a return fuel system, 58psi fuel pressure, super vic, 4150 t/b, 1 7/8 headers,
    what should i be logging in the scanner?
    Sep 2012
    8
    config
    Sep 2012
    8
    drive2.hpl
    I changed the injector a little bit. heres a new scan and helped. but ve still way high
    Dec 2008
    on the Dyno
    1,825
    Whats actual fuel pressure? Gotta get the fueling correct before you try to tackly VE tuning.
    Located in Central Kentucky
    ShorTuning
    Sep 2012
    8
    fuel psi 58, return fuel system. james i sent you email about this and trying to get help if you do remote tuning
