so i have a gen 6 454 in my 1966 impala, running an 0411 PCM with HP tuners.
the car hasnt been properley tuned as its still being built, but i got a flat battery the other day, then a complete non-start issue. it gets really fun.
so the PCM was off a commodore
i wiped the commodore tune and waste 2 credits on a C3500 tune i found somewhere that didnt work (ill refer to this file as C3500) played with that file for a week or so then realised my error and downloaded another tune called L29pipes
installed L29pipes and VROOM, engine roars to life. its not running well, but its running enough to tear up the neighbourhood and generally create havok until i had to park it back up and continue bodywork.
car sitting idle while i do bodywork, battery runs flat (has a clock on the dash that drinks a LOT of power) i jump in, no start, no stress, ill jump start it. jump pack on full.... still no start, check the scanner and banks 1 and 2 are set to pretty much full ON, 88ms or something, the engine hydrolocks and the starter craps out.
ok, now i got no idea why that has happened... here is where it gets interesting:
i got a brand spanking new laptop off a mate. download HP tuners online, install it, then plug in the PCM and download the tune file on it.... the tune file is called "C3500".... the file that didnt work... "thats weird" i think, so i emailed across the file that worked "l29pipes" and load it as a comparison file... the 2 files are totally different... "even weirder" so i email across the old C3500 and load it as a comparison... theyre the same file!!!!
so somehow my PCM has dropped the L29pipes file and reloaded the C3500 file all by itself!!!
is that even possible??? can the PCM store 2 seperate tunes internally and switch to one in error?
but the very best part is i reloaded the L29pipes tune and had another shot at starting it and still no dice. banks 1 and 2 full on and hydrolock... so i disconnect the battery, stick it on the charger, and leave it in frustration.
come back the next morning and car starts and runs fine...
ahahah im happy it works again, but im totally brain-smashed as to why this would happen.
i hope youve enjoyed my story
