Beginning to tune VE with a wideband and logging AFR error % with fuel trims with open and closed loop disabled. everything seems to be reading fine, I am getting and error percent of around 15-27%(commanding 14.6 and reading in the 11's) in most cells up to around 4k rpm. the problem I am having is that no matter how many times I copy the histogram number and paste into VE table the errors never get better and the AFR on the wideband never gets better. Am I missing something in the tune that allowing for added fuel? I thought I got everything but after logging and editing the table 6 times the VE table is starting to look wonky and the errors are still at 15-27%
here is the tune.
Thanks!
