Results 1 to 9 of 9
Thread: flex fuel capability 12579405
    Apr 2013
    210
    i have a 5.3 4l80e swapped old body style truck with drive by cable. I am using a 3 bar map sensor, and this OS supports 3 bar SD enhancement. In such case, would it be simply as putting the flex fuel sensor in line the return line, wiring up the sensor, and pinning the blue connector for the signal the flex fuel generates and enabling the flex fuel capability in the file? Or do these OS do not support flex fuel sensors and just rely solely on the 'virtual flex fuel' sensor?
    If I can use a flex fuel sensor then I guess my search is done.
    Here is the .hpt file
    Apr 2013
    210
    anyone?
    Apr 2013
    210
    bump
    Sep 2008
    1,668
    I don't think the "virtual" flex fuel stuff came to be until newer PCM's than yours.
    Since this one has a stoich table and not just one constant, and a switch that you can set to enable as well as a default percentage to go on should the sensor fail, and a lo and hi fail frequency threshold...you should be able to do it.
    2010 Camaro SS M6. Stock Bottom End, Heads/Cam/Intake/Headers/Exhaust.
    2005 Silverado RCSB. Forged 370 LQ9/Borg-Forced Inductions T6 S484/Jake's Stage 4 4L80E with D3 Brake/4WD.
    2023 Durango Hellcat
    Dec 2008
    on the Dyno
    1,825
    Yes it works. You need to populate the corresponding flex tables like your spark adder table, stoich table, and set DTC's to enable for the Flex Sensor which is labeled "Fuel Composition Sensor" in the DTC Menu.
    Located in Central Kentucky
    ShorTuning
    Advanced Tuner oakley6575's Avatar
    Aug 2011
    421
    Quote Originally Posted by LSxpwrdZ View Post
    This OS does have the ethanol content stoich table but I don't see any flex fuel adder tables in the spark section. Does that mean this isn't a flex fuel OS?
    2003 Chevy Silverado Daily Driver, 408 Iron Block,
    LS3 Heads/Intake, 231/239 114, 4L80e, Yank SST 3200.
    Oct 2013
    550
    Quote Originally Posted by oakley6575 View Post
    The Flex Fuel Spark table is there (Engine>Spark>Advance>Spark Correction>Misc>Flex Fuel) ... but is currently populated with zeros.
    Sep 2008
    1,668
    Make sure you have a fairly recent build of 2.24...it's there.
    Aug 2011
    421
    Quote Originally Posted by MikeOD View Post
    I am still running the 2.3 beta. I'll upgrade. Thanks guys
