2005 Silverado 2500hd
stock bottom end (arp rod bolts)
Dart pro-1 non-cnc heads
prc dual springs
comp 54-469-11 cam
Dur. 285 Int./293 Exh.Lobe Angle 113 deg
60# injectors
how does this look and does anyone see any critiques i can add?
tune
prc dual springs
comp 54-469-11 cam
60# injectors
tune
I pm'd you.
i pmd you back. here is what i changed
You have a mechanical problem. My guess would be valvespring, watch b1s1 dip when your wot as well as map and maf. If you didn't feel it it's not a plug. You have a problem with a hole, suggest fixing it before wot again as dropping a valve would be catastrophic.
Does not explain your map and maf, fix collector leak and try if you like but go cautiously, I think it's something more.
this is a log with the changes you suggested. it didn't really come alive at all.
how did you do pulling?
