When I go to the scanner and press lightning bolt I get message unable to create log.
This is a new hp tuner on a already hp tuned truck
So you are just trying to scan the vehicle while running??
Just hit the play button or press the space bar and it will start to log data. Then you can do the same thing to stop the log and save it. Thats all there is to it, now you have a log with data that you can view.
Did you figure this out? HPTuners aside, it sounds like a file permissions or directory structure error. Try doing a right-click run as administrator when you launch VCM Scanner and see if that makes a difference. You might also check to ensure that your log directory path is valid.
Kenne Bell Supercharged 2003 Corvette Z06
I have the same problem
Ttt
If he is having the same problem that I am, I cant even get the scanner to connect to the vehicle. I turn the key on, connect the cable, hit the lightning bolt or scan option, and it says unable to create log
it wont communicate
Does the little data light on the MVPI flash at all when trying to connect?
Yes it does. Everything works in the editor, the scanner just wont communicate with the vehicle
Ive seen that once on a Chevy Silverado, ended up being a blown fuse. Doesn't hurt checking them.
it has done it on every vehicle I have tried
Sorry, I'm out of ideas. If you are still using an older serial unit I have seen issues with certain USB-serial adapters but if you're on a USB you might have to contact support directly.
Thanks for the help! Im waiting on an email from support.
In most cases this is exactly what it is, in almost every instance where I've seen this it turned out to be a shortcut someone created to our software, ultimately the shortcut was the issue and as long as they opened the software from their programs folder everything was A-OK
