Results 1 to 6 of 6
Thread: PE Enable/PE Delay RPM
    Tuner tonyvette's Avatar
    Oct 2013
    Macon, GA
    52
    I'm trying to figure out which of these settings to use to enable PE. I have looked at some tunes in the repository and most have PE Enable RPM set very low and PE Delay RPM set to where they want PE to enable. Seems like it should be the other way around based on what is described in the help section. Can someone clarify for me?
    Thanks,
    Tony
    PE Enable
    Enable MAP: This MAP value must be exceeded to enable PE mode
    Enable MAP Hysteresis: This value is subtracted from the enable MAP value. If the MAP reading drops below this value then PE mode will be disabled.
    Delay RPM: PE mode is delayed if RPM is below this value. Set to 0 to disable PE Delay and enter PE mode immediately.
    Enable RPM: This RPM value must be exceeded to enable PE mode
    RPM Hyst: If enabled, RPM value must drop by this amount to disable PE mode
    Enable Torque %: Percent desired torque required to enable Power Enrichment
    Torque % Hysteresis: Percent desired torque hysteresis for disabling Power Enrichment
    2012 Colorado 5.3
    Magnum 70mm turbo
    RevMax 2800 stall converter
    DevilsOwn meth
    Potential Tuner thahemp's Avatar
    Jan 2014
    Derby, KS
    6
    IIRC the PE Delay RPM doesn't delay PE until it gets to that RPM, it allows a short delay if the RPMs are below that RPM. If you look at a WOT log with a PE delay, you'll see a delay before the AFR goes to your PE value.
    01000111011011110110111101100100001000000110110001 11010101100011011010110010000001110111011010010111 01000110100000100000011101000110100001101001011100 110010000001101111011011100110010100100001
    x = ac97968bd3df8f968c8cd3df998a9c94d3df9c8a918bd3df9c 909c94df8c8a9c949a8dd3df92908b979a8ddf998a9c949a8d d3df8b968b8cd1
    x = ~x
    Jan 2014
    Derby, KS
    6
    Sorry I think I'm thinking of enrichment rate. I think I just zeroed out the delay field just because.
    x = ~x
    Oct 2013
    Macon, GA
    52
    So I put delay RPM at 0 and enable RPM at 2000. Enable MAP at 75. Seems to be working well.
    Still don't understand why most of the tunes I've looked at are doing this in reverse. Can someone please explain?
    2012 Colorado 5.3
    Magnum 70mm turbo
    DevilsOwn meth
    Mar 2013
    45
    that is to be set per your set up a n/a car wouldn't be as prone to knock unless it is very high compression compared to a roots style blower or any power adder! you can set rpm delay to 0 and whatever rpm you choose I like to bring fuel in fast as possible but look at your logs while watching a wideband and see where you need to be 2000 2500 3000 1500 depends on your set up!
    Oct 2013
    Macon, GA
    52
    Quote Originally Posted by mustangtuner77 View Post
    Thanks for the response. I figured I was on the right track based on what my wideband was telling me. My PE is pretty much activated by kpa rather than by rpm now. Looks like it's working just how I want it to.
    2012 Colorado 5.3
    Magnum 70mm turbo
    DevilsOwn meth
