Originally Posted by
Musky@RG
Car is a 99 FRC Corvette with a 232/234 cam, intake, and full exhaust with stock injectors. So I've basically finished tuning the car, but randomly in the middle of the dyno pull it drops to a reduced power mode. When I look at the logs every time this happens the B2S1 o2 voltage drops from 960mV down to 80mV. The car is running open loop during full throttle but it seems to always happen when this occurs. Can the stock injectors be triggering some kind of ecu failsafe? The injector duty cycles are good in the midrange and hit 95% near redline.
Attached is a log of when it occurs at around 4400rpm:
