Results 1 to 9 of 9
Thread: P1516 REP with TBSS throttle body and X-link
    Ok, just looking for some information. I've researched this quite a bit and most seem to think that the TBSS throttle body is causing the issue of "REP" and they have changed to a gold blade LS2 vette throttle body and everything seems to work. However, some say that its in the tune. Issue we are having is below 95% throttle, everything is great. Above that, code pops up and REP is activated.
    Is the vette throttle body the fix or does the code need to be disabled to keep it from popping up? I've tried the MaxCyl tables with no success. I haven't tried the area vs. pedal tables though.
    Thanks for the help!
    Advanced Tuner blownbluez06's Avatar
    Jan 2008
    Forney, TX
    982
    I've heard of a table that doesn't exist in HP Tuners that can be changed to fix it. Since that's not really an option, I've also seen a guy drill, tap and run a screw into the throttle body to prevent it from going over 100% claim it cured his issue. Beyond that, I've always used the silver blade throttle bodies and been able to avoid the issue.
    Hsquared racing engines RHS 427, Procharger F2, Moran Billet Atomizer injectors, Alky Control,Mast LS7 heads, Nitrous outlet kit,Tilton quad disc clutch, DSS shaft, RKT56 ZR1 trans, RPM Quaife diff. Built and tuned by yours truly.
    Quote Originally Posted by blownbluez06 View Post
    Blown;
    Ok. With the silver blade 87mm TBSS throttle body, how have you been avoiding it? Do you just turn off the code or what's the deal?
    Thanks!
    Jan 2008
    Forney, TX
    982
    Quote Originally Posted by gofish7 View Post
    Blown;
    Thanks!
    Talking about 90mm silver blade vs 90mm gold. Golds don't work without tricks that HPtuners doesn't have and/or that I've not tried. No knowledge of 87mm TB.
    Tuner snowvette's Avatar
    Oct 2008
    Rockford Il.
    135
    I have seen golds work fine in HP tuned TBSSs'. I do know some stock TBSS throttle bodies have had throttle postion sensor issues.
    2007 Chevy Trailblazer SS AWD with boltons GP tuned
    2012 Chevy Cruze A6 LTZ RS Vermount Stade 0 tuned
    Ah...10-4. What tricks does HPTuners need....maybe we can email them to Chris or Bill about getting them added.
    Quote Originally Posted by snowvette View Post
    This is for a 2004 Tahoe that has a 6.0L in it. We put the x-link and TBSS intake/throttle body on it and it only does it at 95% above throttle.
    Oct 2012
    24
    i had the REP issue on start up awhile after the intake swap as i read might happen , so i swapped to the ls7 90mm TB and it fixed the issue, i tried several different tune areas for intake upgrade and tb but it came down to the TB itself regardless of the tune tables for intake and tb i adjusted
    Jan 2008
    Forney, TX
    982
    Quote Originally Posted by xtremesilvy View Post
    This^^ is often the case too. Just a defective throttle body. TAC modules have thresholds in them where that TB may be happy on one car and not on one with a different TAC module. It's important to do your due diligence on verifying the integrity of all the connections too. I've seen pins pushed back in plugs, corrosion on plugs, cruddy grounds on TAC module ground, moisture in the TB or plug all cause issues like this.
