Results 1 to 11 of 11
Thread: Idle airflow
    Sep 2013
    427
    Idle airflow
    Hi there guys, with tuning me mates cam'd L98 etc 06/07 I am after a idle airflow cfg can I use the R.KEMP one or does that only work for the earlier gen3 cheers bret
    I'd like to know about this as well since I'm tuning a gen4 now.
    Senior Tuner Russ K's Avatar
    Dec 2005
    Regina, Sask.
    4,214
    My idle airflow .cfg file is for the gen III vehicles.
    Russ Kemp
    Okay so what needs to be done on a gen4?
    That needs to be tuned if you make any big changes like a cam swap etc right?
    Aug 2011
    17
    I would like to know as well. What I have now is great, as long as my foot is in it. But Idle is TERRIBLE.
    Sep 2013
    427
    Quote Originally Posted by 2004gtols1 View Post
    True 2004gtols1, got it running sweet but still need a cfg for a gen4 .....Please guys does anyone have some input or advice or a cfg that we could use cheers bret
    Potential Tuner thahemp's Avatar
    Jan 2014
    Derby, KS
    6
    My E38 didn't require much attention to get the idle right after the cam. I found the low number in Airflow Final Minimum where the idle started to fall apart, then found the high end where I got the cruise control effect, then set it in between the two. The rest was taken care of by fixing the timing tables. Maybe I just got lucky, but this ECM seems to be very good at managing idle.
    01000111011011110110111101100100001000000110110001 11010101100011011010110010000001110111011010010111 01000110100000100000011101000110100001101001011100 110010000001101111011011100110010100100001
    x = ac97968bd3df8f968c8cd3df998a9c94d3df9c8a918bd3df9c 909c94df8c8a9c949a8dd3df92908b979a8ddf998a9c949a8d d3df8b968b8cd1
    x = ~x
    Jun 2011
    Montreal, Canada
    758
    I cant find it right now but if you search enough you will. 5 liter eater wrote a great procedure for getting idle airflow right on Gen 4's. You have to log idle adaptive spark and idle airflow against rpm. Worked great for me.
    2007 Corvette C6 Vert. A6
    LME LS402, Pat G custom cam, ATI 10% OD Damper
    Circle D triple disc 2600, 3.42 Diff
    YSI, 3.0 pulley, ID 1000's
    Alky Control Meth,
    ARH 1 7/8 headers,
    1009 RWHP @ 7000, 817 RWT @ 6000
    Mar 2007
    Tucson, Az.
    165
    Start at post #171 and then go backwards for everything you ever wanted to know about Gen. 4 idle tuning. Cheers. http://www.hptuners.com/forum/showth...ht=idle+tuning
    SOLD - 2005 C6 6.0 LS2,TF 235 heads, 245/255 .630 113 LSA cam, LS7 lifters, YT 1.7 RR, FAST 102 LSXR, VMax 90-102mm, VMax CNC ported TB, LS7 injectors, Dewitts radiator, Manley 7.550 pushrods, LS7 fuel pump, PowerBond 25% UD pulley, RPM stage 2 '06+ 4:10 rear end, Callaway CAI, 160* thermostat, HP Pro custom tune, LG Pro headers
    Now - 2016 C7 ZO6 A8
    Good stuff thank you ^^
    Sep 2013
    427
    Quote Originally Posted by jim2092 View Post
    Thanks heaps Jim2092 , awesome read, post #85 page 5 cheers bret and also thanks 5-liter-eater ..and use the bill ls2 idle cfg is that correct
