Results 1 to 5 of 5
Thread: E38 Pin # for IAT 2 ?
    Tuner in Training Ag_Sky's Avatar
    Apr 2014
    Broken Arrow, Ok
    26
    On the VCM Editor window Engine Diagnostics/Airflow it shows a IAT 2 table. Is this a sensor input? If so is there an E38 pin # associated with it?
    Dec 2022
    12
    Bump, does anyone know this?
    Oct 2014
    Moscow, Russia
    197
    E38 doesn't have one.
    If using E67 is not an option you have to patch OS for using MT TFT channel as IAT2 and enable IAT2 option switch in the calibration.
    2011 Cadillac Escalade L94 w/LS3 valves and valve springs
    Jan 2014
    Australia
    1,970
    just because some tables are in the tune dosnt mean they are used or even work, if ur working with iat1 then it will be fine just have it in an accurate spot
    Oct 2014
    Moscow, Russia
    197
    IAT1 is used in Throttle Airflow calculations especially at Idle. You can't just move it to the manifold and zero out Charge Temp Bias table.
    Doing so will give you everlasting idle and throttle compensation problems.
