Results 1 to 4 of 4
Thread: Timing not matching main spark table
    Nov 2013
    8
    I took my car to the track this weekend and noticed that my timing is running about 3 Deg below what I have set in my timing table. I have both the high and low tables the same. It shuld have been 18 deg but the logs showed it to be running at 14.5 and 0 knock retard. Whats causing this?
    13,564
    A ton of things.
    Intake temps, coolant temps, torque mngt and many more things can drop timing a few degree's. You need to figure out in your tune what is causing this.
    Nov 2013
    8
    It is the intake temp table. I totally missed it.
    Yeah exactly what 5FDP said. It is 100% going to be your IAT, ECT, or torque management tables. Check them out. Usually the IAT table is the culprit.
