Hey guys, I don't come on here often but I thought I might try to get some help from the more knowledgeable. Long list of mods on the 06 redline, and to cut it short, it wont idle. Anything I do, and I mean anything, it bounces. Relevant mods: 80's, 2.8", ZZP phenolic spacer, ZZP S3 heat exchanger, dual pass, ZZP midlength header, catted downpipe, ZZP 2.5" cat-back resonated, K&N CAI, 1 steps colder copper plugs, E85, LS4 TB, AEM E85 pump, ZZP BRFPS. The things I noticed that helps with the bouncing the most are the over/under speed tables. I attached my most recent tune that is the best at idle, with two logs. I know they are short, they just show the problem of what is happening. Btw, WOT is beautiful, cruising is beautiful, no knock or anything. Except at idle, things get horrible.. Afr goes to shit no matter how much I adjust maf, or the ve table. And when the idle bogs and shoots up, I get some knock. Im not sure if its from my solid bwoody engine mounts though. Anyyyy help would be appreciated!
80e85fps.hpt79.hpl80.hpl
