Results 1 to 5 of 5
Thread: Installed a Nick Williams TB.What do I have to Change in my tune?
    Tuner in Training Luweegy's Avatar
    Sep 2007
    Colorado
    41
    I installed a NW 102 TB on my 06 Z06.What do I have to change in my tune?
    Sep 2013
    427
    Luweegy, ive tuned the nw 102mm tricky to set up mate....where do I start .. RAF/throttle cracker/follower/multiplier etc just to name a few...Does the idle hang/drop below set idle /stall cheers bret...oops yours ETC
    Mar 2014
    McAllen,TX
    160
    I just mess with idle airflow
    Josh Performance Tuning (956)784-0059
    https://www.facebook.com/joshperformancetuning
    I had a custom tune for the HCI setup on the oem 90mm TB. I later switched out to the NW 102, and only needed to adjust the ETC area scalar, mine is at 7150. I didn't touch any other tables!
    From searching in the past, I found that if the car was dialed in already, then a simple TB change would only need the ETC Area Scalar value adjusted accordingly.
    Sep 2013
    427
    Quote Originally Posted by Joshtuning View Post
    Yeah true , i was talking/thinking cable throttle sorry cheers bret
