Hello I am learning here and have a question about the use of Bluecat. I have a E38 ecm that is not eligible for the OS upgrade. The question is if I run Bluecat do I need to use the standard format be it LS1,2,3 and not the formats with the higher map readings. The truck is turbocharged but when I use the formats with the higher Map readings I get weird VE tables(graphs) as shown in the attachments. If I use say the LS1 the graph looks normal. I do have the 3 bar map used in the ZR1 if that makes any difference. Thank you for any and all responces.
