I'm having trouble getting the return to idle sorted out on a ZL1 that came from another shop with these issues. Basically, it will idle dip, surge, or hang when coasting and pushed into neutral with the clutch engaged (pedal released). Idle is good when sitting still and start up is good, adaptive timing is tight. But depending on the style of driving, the car never returns to idle good or the same when coasting.
If the clutch pedal is held down to the floor while coasting the car will return to idle fairly good....and if the pedal is held there till it has came to an idle rpm it will idle good even with the clutch pedal released.
What affect in terms of idle control and/or timing does the clutch position have?
I've played with the base running airflow table and etc scaler all of over the place with multiple combinations and I can't get it to return to idle worth a crap. I've logged airflow and pasted that into the base running airflow table as well minus varying percentages....nothing seems to help. Right now I've got it in speed density mode using a vve table I built from another similar car and the fuel trims are within reason. By running it in SD, I was able to straighten out a ton of timing fluctuation at idle but the drivability remains the same. The car has a custom cam, cnc'd heads, pulleys, long tubes, LS3 tb, etc.
