Im getting my turbo Camaro ready for first start. I have Siemens Deka 60lb injectors(tall). Also known as motrons.
I used the data off of the siemens/dekas website and used the ford to gm conversion spreadsheet from DSX tuning. (Attached and the first tab has the data I am using.)
The spreadsheet spits out Flow Rate, Short pulse Adder, and offset vs Vac vs Voltage.
What should I use for my Short pulse limit?
Thanks!!Copy of Ford to GM Injector Data Conversion R3.xlsx
