Page 1 of 2 12 LastLast
Results 1 to 20 of 29
Thread: IVT Terms
    IVT Terms
    Ive noticed this new addition to the software for IVT AFR weighing coefficient. Does anybody know the impact of these tables
    06 Grand Prix GXP, LS4-full bolt ons, Tuned by me
    Senior Tuner DSteck's Avatar
    Mar 2008
    St. Louis, MO
    4,860
    It's to help with scaling when cheating the stoich afr table. I've been begging for a while... And HPT delivered.
    http://www.dsxtuning.com
    Just say no to bull s***.
    I figured that have somethimg to do with it lol. Now gonna have to find a way to figure it out if needs messing with
    May 2011
    23
    Can you elaborate on this at all. I have cheated my stoic afr table, so what should I do with this table now? Any info on this would be greatly appreciated.
    Daniel
    Pontiac G8 GT
    Advanced Tuner CatnipG5Bandit's Avatar
    Apr 2013
    El Paso, TX
    297
    Quote Originally Posted by HartsG8GT View Post
    I'm also interested for the same reasons.
    2008 Pontiac G5 2.2L (main oil seal became a crunchy Autumn leaf, RIP)
    2016 Fiesta 1.0L Ecoboost - Project "not-so-detestable"
    Mar 2008
    St. Louis, MO
    4,860
    Cut the IVT term in half when you double the stoich.
    Jun 2011
    Montreal, Canada
    758
    Dave,
    Can you elaborate a little bit ? What is this table doing exactly. For example.... If I have my car tuned to perfection (in my eyes. LOL), and I cut this IVT in half, what could improve and more importantly, are there other things I would have to retune?
    Thanks.
    2007 Corvette C6 Vert. A6
    LME LS402, Pat G custom cam, ATI 10% OD Damper
    Circle D triple disc 2600, 3.42 Diff
    YSI, 3.0 pulley, ID 1000's
    Alky Control Meth,
    ARH 1 7/8 headers,
    1009 RWHP @ 7000, 817 RWT @ 6000
    Mar 2008
    St. Louis, MO
    4,860
    IVT affects open loop fueling and transients. When you scale with the stoich method, IVT becomes artificially high. Cutting this value back down fixes the IVT model.
    IVT is a calculated value based on multiple things. The value added is the coefficient for the commanded AFR term. If commanded AFR is double what it actually is, then the coefficient should be half.
    Jun 2011
    Montreal, Canada
    758
    Thank you for the explanation.... Do you think if I change this, I will have to redo the maf and/or VE ?
    Alky Control Meth,
    ARH 1 7/8 headers,
    Mar 2008
    St. Louis, MO
    4,860
    No.
    Jun 2011
    Montreal, Canada
    758
    Just to update.... I cut the IVT terms in half as Dave suggests. Nothing else changed in the tune. Although my car was running great before, it seems to be just a touch better mostly during the first few minutes of a cold start. Could be placebo effect but I am happy with it.
    Thanks for the info Dave
    Alky Control Meth,
    ARH 1 7/8 headers,
    May 2011
    23
    Also made the changes and definitely notice a difference. Mainly when taking off from a complete stop, just feels smoother.
    Daniel
    Pontiac G8 GT
    Tuner in Training ajayniceg8's Avatar
    Apr 2014
    10
    where is the Ivt tab in the software?
    Jun 2011
    Montreal, Canada
    758
    Quote Originally Posted by ajayniceg8 View Post
    Engine... fuel.... general..... IVT terms
    Alky Control Meth,
    ARH 1 7/8 headers,
    Aug 2006
    Cape Coral, FL
    99
    I found IVT terms, but there is two tabs under it. AFR term
    Has to do with alcohol percentage. I am in the process of running e85, but I'm unsure how this tab helps with scaling larger injectors....the mention of cutting this table in half has never said anything about alcohol percentage
    Moderator
    Mar 2014
    Raleigh, NC
    6,347
    Just cut it in half if you've doubled the stoich AFR / cut IFR in half. It's not absolutely required, but does help with intake valve temp calculations which otherwise go overly high with the higher stoich / lower IFR combinations for whatever reason.
    Tuner by night
    CPX Tuning
    2005 Corvette, M6
    ECS 1500 Supercharger
    2007 Escalade, A6
    Stock
    Jul 2013
    Huntsville AL
    164
    Should the IVT terms be changed when scaling a tune manually (using a factor on all air and fuel values)? I have manually scaled all of the air and fuel values in my tune and things work pretty well with the exception of transient fueling (which I know is hard in and of itself). However, I noticed that all of the transient fueling table include IVT terms. My IVT averages about 115-125C (pretty stable as well) while cruising so am I in the right ballpark or should I be adjusting the IVT terms?
    Tuning Addict
    Jan 2015
    6,803
    Quote Originally Posted by sssnake View Post
    Corrected my statement
    How is that calculated? Mine have been logged consistently in the 330 F range - 165 C.
    Edit - did some searching and many people are reporting normal IVT to be in the ~300's F range.
    Tuning Addict
    Jan 2015
    6,803
    Nope - having a senior brainfart moment Was thinking of injector tip temp... Will clear my last post
    ~Greg Huggins~
