Results 1 to 8 of 8
Thread: Flex Fuel Spark Tables
    Jun 2012
    14
    Hey guys, quick question, Does anyone know at what percent ethanol the flex fuel spark table come into play? They are very helpful, but im trying to figure out where the table is coming in at! Thanks!
    Jun 2012
    14
    Bump
    Jun 2014
    40
    I don't know what percentage but I would think that in order for it to be able to tell that you are using FF, you'd have to have the FF sensor and have it enabled in OS.
    Jun 2012
    14
    I have a sensor and it is enabled hahah
    Dec 2008
    on the Dyno
    1,825
    Depends on what the multiplier vs composition table is set to. Seems I had the table available in previous versions but I just looked at my CTS-V file and the parameter is missing along with the selector for Virtual or Sensor...
    Located in Central Kentucky
    ShorTuning
    i'm in the same boat
    Dec 2008
    on the Dyno
    1,825
    I remembered I used the other software to edit a base file with the parameters set for this. You need the Open Loop F/A Blend Factor table to make the spark side of this work. It will also bias the OL F/A tables between gas and ethanol.
    ShorTuning
    Even after changing the OL bias table, it would not work. The sensor reads right... it reads the right percentage but the tables will NOT switch fuel or spark.... any ideas on this?
