Learning hpt slowly
My question Is how can I hold what I command
I try 26 and get 25 or 25.5
No knock and burst knock is zeroed
Ect and iat adders are not set to pull timing for 200plus ° temps
Learning hpt slowly
Could be "Burst Knock Retard" which buffers the spark advance when you step on the gas; or if your Charge Air temperature gets too high it'll also pull some spark.
There's no such table?
Also burst knock and all adders are shut off
my bad misread engine code
did you match high to low table
Yup
8192
are you falling off the timing map cells that command that?
384whp/303wtq
Built 2.0LSJ: TVS w/2.6, 1000cc, Stage 2 cams, custom fuel system, E85, Dual Pass, 3"intake, 3" Catless exhaust, CIA midlength Header
