Some of you had your AFX modified.
I'm curious how they work after the modification? And how does the accuracy compare to before?
I'm also wondering if any of you have used the test gas dyno guys use to test accuracy?
I believe there is a 13:1 and a lower value as well.
A good friend tested his LC1, and AFX with the 13.1:1 gas and found quite a discrepancy. Up to .7 AFR too rich.
Ron
