Results 1 to 6 of 6
Thread: Adding new Pid's
    Aug 2010
    24
    Adding new Pid's
    How to add front wheel speed sensor?
    Advanced Tuner umrjmac's Avatar
    May 2010
    Lenexa, KS
    301
    http://www.hptuners.com/help/demos/a...ove%20pids.swf
    I don't have the app pulled up, but if that is a supported sensor, then that .swf will show you how to add it.
    I found that by going to the forum->VCM Suite Getting Started->Read Me! Startup information, how to's & other Tuning Information!
    It is a sticky-ed so it is always at the top of the forum. Always start with the documentation
    Kenne Bell Supercharged 2003 Corvette Z06
    Aug 2010
    24
    Thanks UMR but cant find wheel sensor pids....I don't know why the speed sensor stops at 158....
    Got to be away to add each wheel speed sensors.... My dashlogic reads it thru obd port.
    May 2010
    Lenexa, KS
    301
    If it isn't in the list, then I would make a post in the feature request forum.
    Senior Tuner mbray01's Avatar
    Dec 2013
    Slidell, La.
    1,015
    hp tuners only grabs info from pcm, and some tcms. if the whhel speed is in the abs module, than it probably won't be available. Now if the pcm sees it directly(not through communication lines) than it might be able to be added Your handheld sees it because it is programmed to grab it from the abs module
    Michael Bray
    Rusty Knuckle Garage
    Slidell, Louisiana
    20yr Master Tech.
    Advanced Level Specialist
    GM World Class Technician
    Shop Owner
    Oct 2013
    11
    Quote Originally Posted by mbray01 View Post
    Torque app can only read the ECM also, and it can read the following:
    224051(front left)
    224052(front right)
    224053(right rear)
    224054(left rear)
    We just need to know how to get the hex address into something HPtuners can use.
