Results 1 to 2 of 2
Thread: injector 028155811
    Apr 2013
    western mass
    142
    injector 028155811
    hi looking for any info on the bosch 028155811 gm number 24508208 out of a supercharged pontiac. I keep finding references to them also being used in an ASA corvette but I havent found any numbers other than the flow of 34.54 at 43.5 psi/ 3 bar in a sticky, but nothing on the short pulse limit, short pulse adder, minimum pulse its everywhere on the 36 gtp 028155868 but not on these
    thanks
    May 2013
    If you can't find the file in HPT format. Download the Corvette 2000 ASA tune file from tunefiledepot.com and use EFI Live in demo mode to access the injector data. As far as I'm aware they are the same spec. injectors and I didn't have any problems using the ASA calibration numbers.
    I even measured them myself on a friends old flow bench and came up with 33.7 lbs @ 43.5 PSI. That was with a slightly denser solvent so damn close to that common figure of 34.54 @ 43.5 PSI.
