I just got my truck fired up last weekend and was able to run it well enough below boost to get about 10 miles on it. I kept the 1 bar tune for testing before going to 3 bar. I upgraded to 3 bar yesterday, copied my VE table rows to the appropriate spots, then did a write entire. Went to start it up and it was running at 10-11.5:1 afr and would barely stay running. I tried making a few changes here and there to the VE but not much better. I've been looking around a bit for a few hours without much luck on a fix.
I finally got it to idle after going crazy on the VE table. Now the VE is all sorts of messed up! Almost the entire thing is over 100's. That doesn't seem right at all. I thought it was just a simple upgrade OS, copy VE values where you can and it runs the same (or at least close to). What am i missing?
This 1bar tune was running pretty good right off the bat on my 402. It's just a 6.0 file tweaked for my injectors and DTC stuff. Timing set low to be safe.
DTCs shut off, timing lowered, 1 bar..hpt
Here is basically the exact same tune just in 3bar.
061214 3 bar running 'best so far' barely drives..hpt
