So just playing around noticed the "IMRC Open" appears to be the only VE table in use on my manual LS3. In pure VE mode, setting 1's to this table, the car starts and stalls, wont run... Leaving the correct MAP in this table and putting 1's in the other two tables, the car runs normally, however they all crank/fire up the same...
Now the question... apparently the initial crank/fire/start up does not reference any of the tables, as with all 1's, the crank/fire mode is the same... after it fires up, then it dies.
I was under the assumption all fueling came from these VE tables, or the MAF table... since now I realize they dont:
1) where does the crank/intial fire up fueling come from?
2) Anybody know for sure if the other two tables are completely unused? Its so much easier not to copy values to two other tables each time
Thanks for any help
