I thought things were going well after reading through some tips on this forum, and uploading the changes.
Yesterday I went for a test drive which seemed like it would be ready for further tuning.
Today, the car will not hold idle (from a cold start). The engine fires up fine, and with some throttle will idle
nicely at 1200 RPM. After settling for about 45 seconds, the idle will hold itself at 1000 RPM.
The trouble is, if I snap the throttle, the RPM will dip to 500 and take a while to stabilize again. Once you're
into the acceleration, the engine feels great. I don't suspect any internal mechanical issues, and I've checked
for vacuum leaks around the intake & exhaust.
I'm uploading the tune that worked best (which is the one programmed before the camshaft and cylinder head
install). The scan is terrible; I know it's bad.
Using scanner controls, the AFR control is best around 12.7 for idle, and timing upwards of 25 degrees.
These are the cam specs:
http://www.compcams.com/Company/CC/c...csid=1440&sb=0
LCA - 109
Intake Center - 103
Intake Duration - 275
Exhaust Duration - 295
Short block is stock. 799 (243) Heads, and long tube headers. Installed billet Fuel rails (pressure 53 PSI).
Computer is 1998 PCM
Engine is 2001 LS1, T56 transmission
Stock injectors, stock MAF
maflwrpt8c_BEST.hpl < There's an error in the Adaptive Idle RPM, MAX ECT. Should be 234 degrees.
cruise_scan.hpl
trev_verify.hpt
I've tried everything from reloading the initial tune again, to starting over fresh using some of the "Big Cam" tips.
Any advice on holding idle would be appreciated. Thank you kindly!
