Last year, I towed my Ariel Atom to a well known LSJ tuner so that they could dyno tune it after I rebuilt and modified the engine. The power turned out ok, but there are driveablity issues and other problems with it. They spent very little time on it, so I'm not confident in the work they did. I attached the dyno chart.
I purchased HP Tuners Pro so that I could look at the program, record data, and hopefully solve my issues.
Here are the issues I'm having:
-Hunting idle, especially with a cold engine. Tried raising the target idle, but it's not able to reach the target RPM.
-Poor driveability at partial throttle/cruising. Car surges/bucks.
-Supercharger bypass valve opens with 2.9" pulley which drops the boost to <10psi. The 3.1" pulley works ok and makes about 16psi.
-The injector tables aren't close to the ones provided by Injector Dynamics for the LSJ.
Here are the engine mods I have:
Custom 3" intake
3" MAF tube
LS4 throttle body
9.5:1 forged pistons
Head with upgraded valves, springs, cams, solid lifters
ID1000 injectors
Dual-pass endplate
Hoop mounted heat exchanger for intercooler
TVS blower with 3.1" pulley
E85 fuel
Are these issues that can be fixed with minor adjustments to the tune, or do I need to start over? Am I better off finding another company to tune it for me?
Thanks.
