Results 1 to 7 of 7
Thread: Changing fuel sending unit values
    Jan 2005
    kitimat bc
    274
    Not sure if this is in the right area. What I'm trying to do is get fuel sensor level through the obdII so my ultra guage will read fuel level. The vehicle is a fiero and the sending unit goes from e- 0 ohms to f- 90 ohms. The PCM I have withe the 3800 is from a 00 Grand Prix and they use I think e - 40 ohms to f - 250 ohms. From what I gather the differences won't allow the PCM to give the correct level. I seen a thread that shows someone playing with the fuel tank sizes and sender values.
    http://www.ls1gto.com/forums/showthread.php?t=399573
    What my question is if I input the tank size of the fiero and put in the fiero sender values, will the PCM now read the correct reading? I would just go out and try it but I will have to wire it in first as with the swap the fuel level sensor input isn't used in the PCM.
    86 Fiero Convertible 3800sc/4T65E HD(2002)
    Jan 2005
    kitimat bc
    274
    I just tried accessing the fuel system panel in the editor and it comes up blank.
    28,268
    means we haven't mapped any tables out that fall under that tab.
    Jan 2005
    kitimat bc
    274
    Ahhhh nooooo, hurry I need it. How come it was working in that older thread link? Also got a guesstimate as to when that might be ready, I won't be able to do what I'm trying to do with out it.
    28,268
    are you using a gto pcm? if not it does not apply to you.
    Jan 2005
    kitimat bc
    274
    No a gtp. Guess that the difference. Any word on when the ability to change tank and sender info?
    28,268
    We have no plans to add any of these for gtp pcm's.
