Results 1 to 7 of 7
Thread: 2004 chevy 1/2 ton no gas gauge
    May 2014
    5
    I had my truck tuned about a year ago. After the down load the fuel gauge went to E and has not worked since. The tunner couldn't fix it. Has this happened to any body here and what do you do to fix it. Any help would be great. The truck runs and drives great. just no fuel gauge.
    it was done with Hp tuners.
    13,576
    It's possible the cluster just went bad, it's very common for them to stop working be it the oil pressure gauge or the fuel gauge or the speedo will always read some random speed.
    A quick test would be to swap clusters with another truck with the same style and see if it works on theirs.
    Senior Tuner mbray01's Avatar
    Dec 2013
    Slidell, La.
    1,015
    I concur^ very common to just quit working. Was just a coincidence it happened then not the tuners fault. Gm issued special policys to cover these for extended periods of time because of this. Get someone with a real scanner, not a code reader, and do guage sweep. either it will come back alive, or youll be replacing it. they are not that expensive.
    Michael Bray
    Rusty Knuckle Garage
    Slidell, Louisiana
    20yr Master Tech.
    Advanced Level Specialist
    GM World Class Technician
    Shop Owner
    May 2014
    5
    Thanks I have had a tech at or shop sweep the gauge. Bet its time for a new one.
    Thanks for the help
    May 2014
    5
    so we did a check with the gm scan tool. The sending unit shows good and we did a gauge sweep and the gauge did a full sweep and is at e still. we will try a different cluster and see what happens.
    May 2014
    5
    mbray01 will the gauge still sweep with the scanner and not work just asking thanks in advance
    Dec 2013
    Slidell, La.
    1,015
    if cluster works with guage sweep, fuel gauge goes full sweep, and fuel sending unit is testing good, then it has to be something in tune. YOu should do a compare of a stock file and see what is different
    Michael Bray
    Slidell, Louisiana
    20yr Master Tech.
    Shop Owner
