i am still having the same problem i have a wideband now and its confirmed that when i power brake it its cutting fuel, but idk how to fix it
What's strange is that it's showing an injector PW increase as commanded and even if the throttle weren't opening as much as commanded, the MAP reading confirms it's open enough. Get us another log of it with the launch and the dying that's occurring. Log your wideband with it this time.
Hsquared racing engines RHS 427, Procharger F2, Moran Billet Atomizer injectors, Alky Control,Mast LS7 heads, Nitrous outlet kit,Tilton quad disc clutch, DSS shaft, RKT56 ZR1 trans, RPM Quaife diff. Built and tuned by yours truly.
What plugs do you have in the car? What's the gap set at?
Is there a possibility that the fuel pump/pickup is being uncovered during hard g-loading (acceleration)? Can you check fuel pressure at the time it lays down?
Its the timing as I pointed out in your other post.
I would suggest to first learn what each sensor on the motor does and the data it relays to the PCM, and how the PCM processes the information to make adjustments.
Maybe start with Greg Banish's material, Don Lasota, and some others off the top of my head. Reading here has a wealth of knowledge as well. Never be afraid to ask a question before you make a costly assumption.
The key thing to remember is that the books will not make you a world class tuner overnight. The books only give you a small remnant of what is going on.
The best way to improve your tuning skills is actual seat time tuning.
POWERZONE- AUTOMOTIVE PERFORMANCE AND TUNING SOLUTIONS
STREET TUNING/DYNO TUNING/TRACK TUNING/REMOTE TUNING/EMAIL TUNING
[email protected]
^^^^What he said^^^^ there is lots of info on here, guides, and links to guides. Some say they are obsolete, I disagree. Read, read, and read some more!
Never give up. The learning process is the best part. People here welling to help
