Injector modeling for twin turbo LSX454
We are setting up a LSX454 with twin turbo's, planning on 9psi boost, using a 2bar Map with massflow sensor.
We ran into a problem when trying to set up the "injector flow rate vs differential fuel pressure" the table would only allow 63.5# injector flow rate.
We are running FAST 65# injectors at 58# of fuel pressure. So how do I get this matched up?
This is our dyno mule for our Hi-performance classes at NADC.
We are running a E38 ECM
If anybody could help it would be much appreciated
Jim Maxwell
Jm2 @ Nadc
