I am not using the proper pedal for this application (Grand prix 2006 5.3L LS4) but was able to wire it to get no codes. I'm also using a 6 wire truck TB 88mm (06 trailblazer) instead of the 8 wire TB, that is stock on the Grand Prix. I'm getting what sounds like ice break mode on Key on, and instantly get P2176 throttle not learned. Tried disabling it and I still get reduced power. If I clear it, and then start the motor it runs fine, no code, until I try to restart, then it goes to reduced power and code P2176.
Question is it the throttle body, or the pedal? Or both? I know ppl swap the 6 wire TB LS2 on the LS4 with no issue.
It seems to me like the TPS isn't set right or maybe wired the wrong direction? Anyone have the GM TAC description For the 06 Grand Prix LS4 5.3L throttle body, and pedal?
