Results 1 to 12 of 12
Thread: Wideband output drops when plugged into HPtuners cable
    Sep 2011
    Jax, Fl
    216
    I'm having an issue when my wideband isn't plugged into the HPtuners cable it reads higher than when I plug it in. Example when the car is off and has been for a while it will output 4.96v at the green connector, immediately plugging it into the HPtuners cable it drops to 4.6v at the green connector even though its still putting out 4.96v at the wideband controller. My box also spits out at least .1λ difference from what is picked up in HPtuners, I know adjust the offset but the problem is its putting out the right voltage its HPtuners that is making it drop. Any suggestions other than changing the offset? because its farther off the farther from stoich it is.
    2006 Holden Monaro I Phantom Black Metallic I Red I One of 416
    L92/L76 I Streetsweeper HTR I SLP LT I LoudMouth 2
    JHP V2 I Powdercoated Black 18s I Kyne Splitter
    2001 GTP I Stock DD
    what wideband are you using?
    Sep 2011
    Jax, Fl
    216
    Modded NGK into AFM1600, I have it clamped directly to the battery.
    2001 GTP I Stock DD
    Senior Tuner DSteck's Avatar
    Mar 2008
    St. Louis, MO
    4,859
    Where is it grounded?
    http://www.dsxtuning.com
    Just say no to bull s***.
    Sep 2011
    Jax, Fl
    216
    I have both power and ground going to the battery and then the input is grounded to the green connector. Should I be grounding it else where?
    2001 GTP I Stock DD
    Mar 2008
    St. Louis, MO
    4,859
    Have you checked your transfer function during start up?
    Sep 2011
    Jax, Fl
    216
    Well that's just the thing, the NGK start up came out perfect .62/ 1.00 but this one is .60/ 1.15 with the AFM function. So I'm pretty sure the NGK didn't have this problem. I'm not sure what the AFM is supposed to spit out though. But even at lambda the voltage only seems to be a little off, like .01 lambda. I'm pretty sure since voltage is changing so much it isn't the function. I'm using V/7.143 +.600
    2001 GTP I Stock DD
    Mar 2008
    St. Louis, MO
    4,859
    The AFM-1600 outputs 1v, then 4v, then 0v. You should see 0.74, then 1.16, then 0.60 during startup. I began using mine last night and it had no issues.
    Sep 2011
    Jax, Fl
    216
    Unplugged from the Hptuners interface that's exactly what I get. As soon as I plug it in it drops. Start up plugged in I'm getting .70, 3.6, and 0.0v. I tried two wiring harnesses still the same. I have deutch connectors for the output wires so I pulled them apart to just wires and same thing. The AFM is spitting out the correct value until it's plugged into HPt. Anyways to check the HPt box? I should have my second AFM box back soon and will check that one to see if it's the box.
    Btw I have my harness power with clamps to clamp directly onto the battery, and the input wires directly into the green connector. I know I didn't used to have this problem because it spit out 1.00L whenever I started up the AFX.
    2001 GTP I Stock DD
    Advanced Tuner c.u's Avatar
    Jun 2010
    Eville, IN
    282
    To test the HPT Pro,May help might not.http://www.hptuners.com/forum/showthread.php?t=23343
    Sep 2011
    Jax, Fl
    216
    Ha I actually did that without even reading it, the battery checks out 1.5v. I put my multimeter on the screws of the green connector, unplugged into the hpt it reads corrects, plugged in with both usb and obd2 cables plugged in it's off. If just the obd2 cable is plugged in to the interface it is off. So I'm guessing my obd2 cable is messed up. I may try it in my autoprom device later to make sure it's not a grounding issue with the harnesses. But I've tried 2 vehicles, two harnesses and same problem.
    2001 GTP I Stock DD
    Sep 2011
    Jax, Fl
    216
    Cut clamps off, resoldered them with a new iron and all is correct again.
    2001 GTP I Stock DD
