Results 1 to 3 of 3
Thread: ctsv ckp code at wot.. only in first
    Having a problem out of nowhere every time I floor it in first it sputters in and out but only in first. And if I do not let out quick the tach goes to 0 and throws a ckp code. If I turn the car off for 10 mins it is back to normal. By the way its a 2006 ls2 ctsv
    Advanced Tuner Montecarlodrag's Avatar
    Nov 2009
    Pegasus Galaxy
    919
    Crank reluctor play, loose ckp sensor, loose battery or power cables.
    It may also be a ground issue or bad wiring
    9 sec Montecarlo SS
    ckp issues.hpl
    ckp issues 2 did not die.hpl
    here are 2 logs of it happening one it just shut off the other stayed running the one it died on i got ckp cel
