Results 1 to 6 of 6
Thread: how do i change the transmission gear ratios
    May 2014
    8
    Hi all, I went through my 4l60e and installed the patc power gear which changes first and second gear ratios. I cant find any table that has the gear ratios listed so I can change them. Ive searched the forum till my eye are about to bleed. Thanks for any and all help-prestons
    May 2014
    8
    Well aparently when you use the different ratio gear set in the 4l60e the shift points are close enough to drive it and make adjustments on. When i bought my power gear from patc they said the ratios would have to be changed in the computer, and if not it wouldnt shift and would throw codes for incorrect gear ratio. Another forum said all the adjustments i need to make is the shift points. So i took the truck out and made some logs that i screwed up when i went to save, and it drove good. So if anyone else does this to their trans and comes searching for answers hopefully this helps. I was thinking there would be a table to set the ratios on like the one for the rear end and tires.
    Advanced Tuner c.u's Avatar
    Jun 2010
    Eville, IN
    282
    See if you have it.
    May 2014
    8
    no in mine I have the same tabs--auto shift properties then general and under that I have a drop down menu that I can select different transmissions and under that it has a drop down menu to select performance option switches all that is there is general and force motor current no ratio selection. I would take a screen shot like you did but I don't know how. thanks for responding
    HP Tuners Support
    (foff667)
    Bill@HPTuners's Avatar
    Hailing from Parts Unknown
    28,268
    email me your file.
