I have a 2008 AWD Trailblazer SS with a totally stock engine (top and bottom end) and a TVS1900 with 2.9" Diameter pulley, GM 50#/hr injectors (12613412), LS2 Car throttle body (4" diameter fender well intake), LS3/7 MAF, 3 Bar Bosch MAP, 1-3/4" long tube headers with dual 2.5" exhaust, NGK TR6 plugs (.035" gap), plug wires, etc.
I have a few questions related to the engine tuning process. I have searched tirelessly on these issues with very little overall luck.
A few things to keep in mind:
- I live in Denver and the average barometric pressure I see on my MAP is about 82-84 kPa vs many areas 98-100+ kPa. What this means is that nearly the first 3 psi of "boost" are just to make up for the big disadvantage up here (for the racers here, 7000-9000 DA is common)
- The best pump gas I can get here is 91 AKI with "up to 10% ethanol" or 91 AKI with 0% ethanol ($$$). Id like to be able to just pump 91 in and drive it.
- The maximum boost pressure I see is about 135-140 kPa which is 7.8 PSI above atmosphere here or about 5.5 to 6psi at sea level.
- I am tuning in open loop speed density right now with lambda error plotted. I have a NGK AFX wired to my MPVI Pro.
So, a few questions:
- How do those of you with automatic transmission drive the vehicle to tune? Do you select a specific gear and hold it to get into the high load/low RPM and low load/high RPM areas to cover the entire VE table (or as much as you can cover). Driving under normal conditions when the TCM is picking gears the vehicle will never see these conditions (top right and bottom left of your typical VE table), correct? Its also very hard to capture wide open throttle data because you get so few data points per pull. Do you guys just do a lot of WOT runs?
- I am getting quite a bit of knock retard. I need to burn up what is left in my tank and put some fresh 91 AKI in to verify the fuel is "good". But one thing I have been able to find very little info on, is typical spark advance for positive displacement superchargers like the TVS1900. It obviously needs to be a lot less than a naturally aspirated vehicle but are we talking single digits, low teens, high teens? You will see in the log I am getting KR at typically around 12-18* of advance. Also a lot during throttle transients which brings me too...
- I have some transient fueling issues. I have read everything I could find on this and have made some changes to the tune that I need to test. If anyone has tips on transient fueling as it pertains to a TVS1900 let me know. This thing builds boost immediately so the transient fueling is very important. I have basically increased the fraction of fuel that will evaporate from the port walls slightly, and then more aggressively increased the fraction of fuel that impacts the port wall, particularly in the high MAP regions.
Those are pretty much my main 3 concerns. Find attached: a Log (look at 2:10 to find a WOT run) and Stock and Current Tune. Any insight or experience anyone has to share would be appreciated.
I am all ears.
-TBSS - TVS1900 - SD OL.hpl
-TBSS - TVS1900.hpt
-TBSS - Stock.hpt
