Hey was hoping someone may be able to look at my tune and tell me what I've got wrong. It's somewhat of a bastardized tune I threw together to get the car running. I have a 99 GMC 5.3 PCM, running the stock OS, adjusted everything for speed density, fuel/ignition maps for an L33 were copied over, Idle/trans settings brought over from an 02 LS1 tune. My problem is the car has poor throttle response coming off idle, and it doesn't seem to be making the torque it should when starting off. Any inputs? Or is this just a matter of getting my WB set up so I can tune the VE?
Thanks,
Chris
93 RX-7
05 L33 98k miles
LS1 intake manifold
F-body accessories
Drive by cable
Truck map sensor
50lb injectors for when I go SC at the end of the year
Corvette FPR
1 3/4 mid length headers
Otherwise stock
